Can it be done? When they rebuilt my engine they did it with the engine installed. The mechanic said if he had it to do over again he wouldn't think twice about yanking the engine. If you are ONLY changing the cam perhaps you can get away without pulling the engine, but the access you'll have will be limited. You'll work easier with the engine out, obviously.
