The studs aren't bent, they are original, and there is a lot of anti-seize applied.
It's as if the bolt circle diameter on the studs are a few thousands bigger then the bolt circle diameter of the wheels. (Or the wheels shrink when cold).
I can probably fix this if I ream the stud holes on the wheels larger.
Because the wheels are mag I've always been concerned about trying that. My wheels feel like there are hardened steel seats in the wheels, but they don't show it.
Now this happens when everything is cold. Considering the reputation mag has for expansion and contraction maybe that's the cause. I can't tell you if I can get them off easier when the car is hot because I never tried that. So much for the sceintific method huh?
You guys, the wealth of the known Pantera knowledge in the Universe are going to tell me you have never heard of this problem, issue, delema, dillusion?
I'm scared!
