Originally posted by David B:
George,
Just looking at your seat rails reminds me of what mine looked like. But it's not the rails that hang you up. It's the rollers.
All you gotta do is get new BRASS rollers (Hall has 'em) and for a few bucks your seat will slide back 'n forth like a new luxury car.
A few Bucks? Closer to $80
Hi George,
I'm enjoying this thread. Do a search on 'seat rollers' and you'll find some threads on this topic. I did mine (one of the threads you'll find) and replaced with "Deltrin" rollers from ProFormance and they work PERFECTLY. Totally night and day difference. I also put thicker ss washers under the rear bolts to keep the bottom of the seat from rubbing too hard on the floor and thereby binding.
Clean the runners, do the rollers, insert washers, you're in business.
After you clean the rails, add a little waterproof grease and add 2 solid rollers to each rail, you may still find the seats still don't adjust easily after installation. If so, it's almost always because the floor is bent. Remove the carpet and eyeball the floor. If obvious dents are seen, the floor is quite thin and easy to straighten with a hammer and a 2x4, or a floor-jack against a dent. And do NOT discard the spacers that sit against the floor and protrude thru the carpet, that the rails sit on. Trying to lower the seats by discarding the spacers bends the seat rails when you tighten up the bolts on each end, and bent rails won't adjust easily. If you must lower the seats, cut the carpet away the full length of the seat rails so they sit flat on the floor. This lowers a seat about 3/4".
Thanks for the info guys. I will look in to getting the other rollers, or just put 4 of them on the driver's side seat. I rarely adjust the passenger side. I did check the undercarriage and floor pans and nothing is bent or dented THANK GOD! I'm not worried about the height of the seats, I just want full travel back and forth on the driver's side. The rails are cleaned and I have some White Lithuim grease for the rollers that should work well.
George
I wish my @##$@@ Valve Cover gaskets would come in!!!! I want to drive!!!!!
Next is a series of shots of the seat rails while I'm still waiting for my valve cover gaskets!!!! Come to find out today, the order was NEVER placed! (New employee) I'm ok with it, my neighbor is the owner of the store and he brought me a 6-pack tonight to say he was sorry. Plus, I'm headed out for CT. in the morning to go to a party at my sister's and I have Monday and Tuesday of next week. They promised the gaskets will be in on Tuesday!
(Fingers crossed)
George
Sorry,
I forgot one other thing. Since posting that my old setup wasn't going to be used again. I've had a few IMs asking about selling the parts. My question is, should I sell everything as a complete package? I know the stock air cleaner really doean't matter, but the carb and intake seem to me to be a "matched" set. A shot of the bottom of the carb.
  • DSCN2176
Dos this mean that this carb will only work on this intake? Also, I've been asked what I want to sell these 3 pieces for, I have no idea! I know what a Shelby original carb and intake go for, but this is not the same. Trust me that I want to be fair and not sell anyone something that will not work on their car or try to take advantage of them and way over charge them. So please, any assistance would be GREATLY appreciated! To the guys who have inquired about these part, I'm sorry that I haven't gotten back to you, but my wife has been sick, and I wanted to make sure I was doing you right.
IM me if you have any questions.
George
