I had to rebuild the carburetor due to leaking and old age. I thought it was an after-market Holley that was mounted an Edelbrock manifold. I believe now that it is a Holley that was made for Ford during that era. The part or "list" number is 9510 which is stamped on the horn, which means 735 CFM model 4150. I didn�t know these details when I purchased the re-build kit and the speed shop counter guy had difficulty finding a kit to match.
I have re-built many carburetors and they always worked fine, but this one now has a problem that it did not have prior to re-build.
Idles rough, and a long dead band between idle and about 1,500 RPM. Dead band meaning no increase in speed as the throttle is opened then rapid increase in engine speed to 1,500 to 2,000 RPM. The carburetor changes sound at that point. Operation above this speed is fine. This problem happens in the garage or driving.
I have the idle adjustment screws at nominal poisition,1 � turns. Power valve = 6.5" vacuum, floats set correctly, accelerator pumps squirts.
Any suggestions??
[This message has been edited by Jon3613 (edited 05-20-2003).]
[This message has been edited by Jon3613 (edited 05-29-2003).]
