You will need some good snap ring pliers to get the unit out.
Also, I am a big fan of the Motive Power bleeder. It is a pressurized reservoir of fluid that will screw in place of the master cap. You pump it up, crack the bleeder on the slave and let the fluid flow for a bit. One person operation, easy and quick.
