Hello, you more-experienced-Pantera-owners. May I ask for some advice.
As I´m not experienced in this engine stuff, not at all, I decided to ask before starting to take bolts off.
I ´m changing Armando´s oil pan and pick-up into my 351C. Before removing the old oil pan I did not really understand that changing the pick-up does not mean just "throwing it in". Looks like some parts have to go off before this can be done. Things nearby pick-up, are they oil pump, oil pump drive shaft, or what are they? Is there something I should consider before I start taking the parts off? Will I need some new gaskets for this job? So I´m not talkig about the pan, just about the pick-up.
The engine is out of the car, and the whole car is in bare metal. We were just planning to put the engine with some new parts (intake manifold, starter, Armando´s oil pan) and the just-fixed-by-Paul-Fleming-ZF together and test the whole package into my Pantera before I continue with the metal work.
