I also want to Point out just like @rocky did, that an additional voltmeter is a very, very good idea.
Like you can see on this picture I connected the wires backwards on the Ammeter… it was showing charging, While I was actually discharging the battery … Another mistake I made - corrected since.
Secondly, I bought a voltmeter on Amazon and just installed it in one of the Surrounds of One of the five New not working headlight switches… Nothing a Dremel can’t Adjust to fit. Once I had that installed I actually found that I had a short… It was up in the right fender under the headlight… Mega voltage drop… (meltage -) later another time I found that my voltage regulator wasn’t working either…
I did install the bridge on the back of the ammeter which, as previously was pointed out, dilutes the reading of the gauge.
Some of you know that I had quite some electric gremlins in my car… Most of them I did inherit when I bought the car and others…. Well, I have to say a couple I may have induced myself… But now everything is working absolutely everything.. and that little voltmeter is a very easy way to see if there’s anything wrong… ammeter It’s good too, but Just not as blatant.
also note my 100% reliable light switches… As I said… Nothing, a Dremel cannot make fit… Well, almost…🤪
