I started a job at a non-profit machine shop….  Well it’s like a job, except for the “pay” part.  All the money we take in goes towards the operation of the “Old Pueblo Transit Museum” (or towards new tooling for us!)
Anyway, it’s fun, I’m learning a lot, and I get to work on a lot of my own projects.
I know we have a bunch of good machinists on this forum, I thought people might want to post up their shops, or some of their products… (I know we have some current active projects going on now in different threads…)
Here’s our new Archdale radial arm drill press.  It is an English “reverse lend-lease” item, payback for our support in WWII.  It has an old “US Air Force” inventory tag . In the back is the biggest Do-All Bandsaw they make commercially…  Both were donated to the museum, with all fixtures.  Really good stuff.  We paid for the shipping from the Solar Observatory (Sunspot) in Alamogordo, NM.
IMG_2698
IMG_2700
This is our massive lathe…  it has a 24” chuck, and (I’m being serious, but I may be underestimating it), a 25’ long bed!  The story is it’s German war reparations, made out of scrapped Panzer tanks! We are thinking of going in to business of making 16” gun barrels for battleship museums!
IMG_2631
Lastly, I’m scraping the bed and the ways on my home Craftsman lathe.  Scraping is an old school technique to transfer flatness from a standard (granite surface plate) to another surface (in this case, my lathe carriage).
IMG_2749
Enjoy the pictures!
Images (4)
  • IMG_2700
  • IMG_2698
  • IMG_2631
  • IMG_2749
I worked for a company that bought out and scrapped a  nearby company. Inside was a 6" lathe and a small tool-room mill, both fully tooled. I bought both even though I'd never worked on either. After changing the 220v 3-phase electric motors for single phase 110V ones for my garage, the first thing I made from scratch was a handle for one of my wife's cook pots that had cracked. Life is a learning experience- that was 50 yrs ago, I still have them & I'm still learning!
Rocky, my lathe is a 6" (radius/12" OD) Clausing. With a h....uvalot of fiddling, I made a 1" aluminum spacer for under the headstock, the tailstock and a 1" riser under the tool post. My old lathe now swings 14" OD- just enough to face a Ford flywheel. Small shops routinely add a 4" thick  spacer to milling machines to increase their vertical reach. I saw no reason the mod wouldn't work on a lathe, just more trouble, especially in the geartrain. But mine has been working for 25 years now. New bearings help a lot with the precision.
...If I may add this,
I see in Rockys' Photo, a Magnet Mounted 'Dial Indicator'. I have said in the past, the 'Micrometer Dials', on the Carriage, Cross-Slide and Top-Slide, are Useless!
They do not 'Compensate' for 'Worn' Play and Back-Lash. The Dial Does not 'Lie'! One can work to the 0.0005" using a Dial Indicator. This does Not Account for Tool 'Push' and Tool Wear.
The technique is to Keep the Screws 'Loaded' In the Direction of the Cut, 'Under Pressure'.
(2) Dials can perform a Taper by taking the Taper per foot, dividing by 12 to get taper per inch. One dial covers X for one Inch while the Second Dial covers Y. The adjustment is made at the Top Slide, and then cranked by Hand. This is More Accurate than the 'Protractor' at the Top-Slide, that would get you Close. If you should Not have a 'Taper Attachment'.
I have worked on a worn-out Lathe, when I first started working at LFW, They closed their doors a few Years Ago. That Lathe had a Backlash, on the Carriage of 0.019". With the Dial, I could work to Less Than 0.0010"...all Day Long. Earning the Praise of My Mentors. "Any Machinist can work to a 'Tenth' (0.0001") (a 'Ten') on a Newer Machine...It Takes a 'Master', to work 'It' on a Worn-Out, Broken Machine". Broken, as the Headstock/Spindle Bearings always Rattled around, in Use, from day One. We had Many Other Lathes, they were Testing Me to Prove My Skills. Even though there was 'Sometimes' a Tolerance...I always put the 'Needle' at the Zero! 'Cut' to less that 0.001" and 'Polish' to Exactness. This was Demanded of the Job!
I Never worked any Machine, without using a Dial Indicator, in that Shop or Mine!
"The Dial does Not Lie!"
As in any Instrument or Measuring Tool...if You 'Drop It', consider It No-Good!!
This 1939 Atlas Standard Gear Change lathe has been with me since the ‘80’s and has served me well 5” rad 10” diameter and a 42 inch bed. The Rockwell milling machine has only been with us for 12 years. I’ve had access to machinery throughout my working years first as a tool and die maker and later working in Advanced Engineering and manufacturing roles. Still have a few connections if I need larger scale equipment. IMG_0990IMG_0989
Images (2)
  • IMG_0990
  • IMG_0989
Here is my Chinese-made lathe that I have had for about 30 years. I got it for free when the company I worked for closed its small mechanical maintenance department. 17'' maximum diameter and 5 feet length between points.
20250124_171101
It was quite an adventure when I had to move it between Alsace where I previously lived and my current home in Corrèze, 850 km away:
20191012_09485820191014_12401020191015_121800
And here is the milling machine that I bought 4 years ago, before that I didn't have enough space:
20250124_171732
With the lathe I was also able to recover a whole collection of measuring instruments:
P2010858 repérée
Images (6)
  • 20250124_171101
  • 20250124_171732
  • 20191012_094858
  • 20191014_124010
  • 20191015_121800
  • P2010858 repérée
That’s a lot of good stuff!
I have actually been fairly successful in finding good measurement equipment on eBay.
I have a fairly complete set (at reasonable prices) for the type of work I have done so far.
I just read this, and thought it was interesting enough to add to the discussion….
IMG_2930
  • IMG_2930
