Good for you! A small power brake unit can be used to run a clutch for hand operation. I'd use a diaphragm clutch like Centerforce which is easier to push than the 3-finger Long type. See the 'Boss Hog' a -350 Chev-powered motorcycle w/hand clutch for an example (built commercially in TN?) Does the hotrod have a mid-engine & ZF trans or front engine?
Thanks! It has the mid-engine w/ZF trans.
