i have the sandeen style made in china compressor that makes a hell of a whine.. do you have the part number on the actual sandeen and where to buy? i have kirk evans bulk head reduction kit
I don't have the part number on hand but purchased mine from Dennis Quella as part of a complete kit in December of 2022. Compressor cost was $465 plus shipping at that time.
Somewhere in this process, it needs to be remembered that the compressor will be different for the two common refrigerants, OEM R 12 and a conversion to 134a
I think the only difference is the type of oil and the hose connections. The hose connections can be whatever you want based on what head you order. I use a head with O-ring connections and r-12 charge ports.
