Use steel doughnuts. you may have to tighten them a couple times a year, but they never wear out. I tried Jacks idea of using a flat gasket but the 1/4 to 3/8 inch to pull the pipe to the header was to much angle for the muffler hanger to compensate for. I guess you could relocate the hanger. Anyway, I went to a GTS exhaust and no longer use the above setup, but it worked well for me.
