Time to drain the system and renew. Right now I use Prestone at a 50/50 ratio with distilled water and I have a couple bottles of Redline Water Wetter in. Freezing is not the concern; the Arizona heat is. Opinions welcomed.
I use a 50/50 mxture, regular water and one bottle of Redline water Wetter. No kidding John, specially with our temps lately.
Originally posted by RRS: Time to drain the system and renew. Right now I use Prestone at a 50/50 ratio with distilled water and I have a couple bottles of Redline Water Wetter in. Freezing is not the concern; the Arizona heat is. Opinions welcomed.
