The GTS clone project that I received in February came with a gasket issue on the timing cover and I am in the process of replacing it.  Once the timing cover was off, I noticed that the bypass port on the block has been plugged.  My thermostat housing has the brass plate for the proper 351C thermostat with the hat.  I bought a fresh Track Boss thermostat from Tim Meyers for this car and it would have been a waste if I tried to use with this plug in the block.  I am glad I stumbled on this plug and will be removing it shortly.
  • mceclip0
