Under the car, should the hose that connects the hard tube from the expansion tank to the 6' tube on the right side be straight or 60-90*? I have a new silicon hose kit and every piece is straight. It looks like the 8-ish inch piece of straight hose would kink severely if I try to install it. The rubber hose I removed was molded.
Anyone have a good undercar closeup pic of the large cooling hose and heater hose routing in that area?
As always, thanks
