Can anyone tell me how the grills on the cowl (the ones that the wiper arms sit on) are removed? I heard that some of them have retaining clips and some have screws. I've tried pulling up on it but if it has clips, they aren't budging. If it is screwed down, how do I get to the screws? I have a '73 Pantera L. Thanks in advance guys!
they should just press into plastic clips. I believe the ones that screw in you can see the screws. Don't pry up on the edge it will chip your paint. I use a tool from Home Depot. It is like an awl only the last 3/4 inch is bent 90 deg. I insert the point through the grill near the end past the bend, turn it so the blade is perpendicular to the grilles and lift.
Good luck
Gary #06984
AS F-GT says, there are tiny pins that lock into plastic grommets in 6 places. Trouble is, 30 yrs of age causes the plastic to get very hard 'n brittle, so they don't flex enough to release the pins. Usually results in the owner tipping the grille to one side during the removal process, which then snaps off the delicate die-cast Zinc pins.... which are not, practically speaking, reweldable. Pull STRAIGHT UP only. If the worst happens & you snap a few pins off, one can drill & countersink holes exactly where the pins used to hang down and use small self-tapping screws into what remains of the plastic grommets. The results are no worse than the look of aftermarket units IMHO..All the vendors sell replacements using screws
