Can anybody tell me what differen there are between a coyote engine sitting in a 2014 mustang. and a coyote engine in a 2014 F150 pick-up. If there are any?
joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
They have a different rating 420HP/390ft/lb TQ for the Mustang vs. 380HP/380ft/lb TQ for the F150.
Here's what I found;
The 5.0 liter is beefed up for truck duty with specific exhaust manifolds, slightly lower compression (10.5:1 versus 11.1:1) and new heads with different valve angles (to allow for fuel cooling of the intake charge). The camshafts are also less aggressive and tuned for torque compared to the Mustang GT application.
The Boss 302 variant certainly has reworked heads and different internals, with higher compression ratio again.
It is much easier to find a secound hand Coyote engine from a F150 than one from a Mustang GT. And also cheaper.
The slightly lower compression must be a + for putting a supercharger on it,but dont know hav the different Heads and camshafts will Work with a supercharger? Have to see.
As far as I know the F150 has different camshafts and a different oil filter pedestal. I think other than that they are the same. There are several aftermarket options for ecu that will control VVTI. My personal preference is Link engine management (ViPec). When I originally did the swap in my Meteor in 2012 I worked with them to develop the trigger patterning for the Coyote. As far as I know we were the first ones to get a Coyote running on an aftermarket ECU with fully functional VVTI.
