So I am growing tired of my oval air cleaner. I never really liked it in the first placee. My car has the engine compartment painted grabber blue and I'm running 180's with a four barrel carb. I would like to design / install a rear facing scoop sort of what they use on the blown dragsters but rear facing. This is just an idea. I am looking for input. Picts would be helpful. I remember seeing a member installed a forward facing scoop in the roof. Looks cool but too much for my car. What do you guys think?
Here is what I am using on my Pantera. It is a Spectre air box with an offset base. It clears the rear deck and the side air scoops work. I just ran a data log on the ECU and the inlet air temperature is almost the same as ambient.
JFFR - Would you post the part number for the Spectre air box that you are using? I have a lower manifold, the Blue Thunder. Based on your experience with their parts, which model would you recommend. I am building the same configuration as yours with 4" intakes. In hindsight, would you have considered the customizable solution the offer to more precisely aim the snorkels? Thanks
Can we see a picture of the intakes from the outside of the car?
Here is what the scoops look like from the outside of the car.
If you go to the Spectre website, they have a listing of all of their parts. My air box is a 14" 120 degree unit. The base is also a Spectre 1 1/4" offset. I haven't had time to remove the snorkels and point them up. It would make attaching the hoses a lot easier and make the set up look cleaner.
Great job Stenmark! Do you have a CAD file for your intake manifold? I'm planning to make my own intake for a custom EFI system and I'm looking for a CAD file for the intake manifold valley plate and intake flanges - it would be nice to have them laser cut rather than doing a lot of hand fabrication.
Thanks!
Garth
