I've been thinking about trying to find a decklid for my Pantera that is similar to the Ferrari 360 where you can see through the glass to see a show quality engine. Has anyone ever done this or heard of anything like this available from the well known suppliers? I'm guessing there may be others interested in something like this...
One mod I've seen that I thought was very cool to make clearance for webers was to cut the entire front leading edge of the decklid back to clear the webers, rather than notch it around the webers. You couldn't tell to look at it that it had been cut, unless you compared it side by side with a standard Pantera decklid, then you could see that the angle going up to the top of the decklid was steeper.
I've also seen a number of modified trunk tubs that replace the front wall of the trunk tub with plexiglass.
