Have you tried just polishing the contacts with contact cleaner (both sides) and scotch brute (or something finer)?
From the picture you posted, it looks like the buttons just short across the two adjacent rings on the circuit board…
you could probably make a temporary power harness, and test the clock with the faceplate off…
if you haven’t already try a Google search for a term such as veglia digital clock manual.
I put in that search term and though I didn’t find an exact answer for your clock, there were a number of threads with interesting information.
the red button may just be an illumination button from what I read. Holding the left button while pushing the right button may also get you into a different menu
