joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
It depends on the reservoir tank capacity, Peterson (dry sump component manufacturers) recommend about 2/3 full as a guideline to start on a fresh engine then let that cycle through the engine and see where the level is. Oil viscosity depends on the engine tolerances, but I use 15-50W racing oil.
I would expect your oil tank to have two screens. The oil level should be between the two screens when the engine is running at idle speed. You can run with the level just below the upper screen if you want to carry more oil, but stay below the upper screen when running.
