I think the idea should be that you locate them where you can get at them "in a pinch".
In the engine compartment you would need to put them on the passenger side of the bulkhead and generally speaking that means access is either through the right rear wheel well or under the car.
The interior bulkhead panel isn't that easy to get off in the dark along the roadside.
That is where you would put it in a race car though.
The location is for quick, easy access. The thing is made to mount in the engine compartment. It doesn't care about the heat in there.
I hear you PanteraDoug, and I appreciate your and everyone's comments as usual, but in the dark on the side of the road, I think I would rather remove the two bolts holding the firewall cover in place to gain access to the modules with the interior light right above. Otherwise, I'll have to carry a jack to lift the car enough to be able reach into the HOT firewall area to, say, switch over to the backup Duraspark module should the primary module fail. That's not an easy area to access even on jack stands in the garage.
I've never had a problem removing my firewall cover. So, in a pinch, I think I could simply remove the firewall cover bolts and lift and lean the top forward a bit to access the modules.
Of course, this all depends on whether or not I decide to mount the module(s) on the cockpit-side of the firewall. The MSD box that failed was on the car when I bought it 13 years prior. Duraspark and other boxes are designed to live and survive in a hot environment. Thus why I'm still on the fence on where to install the modules since they rarely fail.
BTW, When my MSD failed, I jerry-rigged a Duraspark module in the same location just to get me through to the end of the cruise-in season. It worked, but it's time to clean up that wiring mess.
Enjoy,
Ron
