I have never seen one with a blocked heat riser passage although it's been made for 40 or 50 years so who knows why they vary. I'd take a guess and say they are pretty rare and an additional guess in that maybe it was made as a "competition" only manifold?
I thought maybe you were confusing the Torker with the Scorpion? Me bad.
I've seen them with and without the "fingers". Mine had them. I had three Torkers plus the Motorsport versions for the  A3.
Best of luck in finding one.
  Hey panteradoug,
    I just checked my pics and the exhaust crossover openings on the intake runner side flanges DOES have the openings in it and the casting for the exhaust cavity, but the actual opening on the top of the manifold is blank. Even the one I just looked at on Wallmart site is void of that heater opening.
   I just wonder if I order one if that opening will still be blanked ?
    At over $450.00 for this piece it would really suck if it was open for the heater !!!!        Stay safe and well !
   Les Gray
@cuvee posted:
As funny as it sounds, I just check WalMart! They seem to sell the Torker 2760? Sold and Shipped from TPM?
Hey Les... I was just as Surprised as You about WalMart (hopefully) being able to get this Manifold. Not sure who TPM is but good Luck! Being Retired, seems I got More Time on my hands, and as Lame as it sounds I kinda enjoy the Hunt for Old Stuff!
Curt Hall
Les. I'm the wrong one to ask about this. I would think that the un-machined choke well version should have it's own part number?
If it were me, I'd call Edelbrock Tech and ask them for clarification.
I haven't used the Torker in 25 years at least and am not aware of what changes they made to it.
My impression however is that the unmachined version is one of the first offerings from Edelbrock, not one of the newer ones?
IF I was the Edelbrock Tech guy and you told me that you wanted the blocked un-machined version, I'd just tell you to block it. I ran a 4779 750 Holley with a manual choke and just made a 1/4" thick aluminum plate to mount on it and block it. To me, it was no BFD and not something to worry about at all.
I never put these things on a dyno but for the life of me, I don't see where it matters one iota whether or not the plenum has tabs to it. The location of the carb throttle plates to me, makes that totally irrelevant?
