Thank you for this information Fredrik. It is very helpful to me.
I'm studing as hard as I can. Is there a test?
I see where some suggestions on CPU's and systems are coming from already. Some of the updates that I see may be making those recommendations obsolete.
I'm looking at the Haltech E6X. The only advantage that the Electromotive has that I see is the "exclusive blending of TPS/Speed density" lookup charts for idle.
I'm not sure if it is worth it considering how difficult it is to get Electromotive Technical support.
Haltech is just the opposite. I guess things have changed in the last year?
