Hello
I'd like to change my 2 stock electric fans with 2 new ones that are able to flow more air. (I want to be sure that my car will not run too hot this Summer!)
I want to put them in the same place of the stock ones
Does someone know wich one to order (summit or else for example)
Thanks again
Thierry MONNEY
A pusher fan is not as effective as the sucker fans currently available. I recently
upgraded mine, and while I am still putting together the story for my website http://geocities.com/provamo72/ you can order the same package I did. www.summitracing.com. The product is Flex-a-lite (Part # flx-220). You can order with or without the adjustabe thermostat. The cost without is USD$179 (without thermostat) and $20 more with. It comes mounted in a shroud. I took my (nearly) stock radiator and had a couple of brackets fitted to hold the fan assembly (don't use zip ties !). I also flipped the upper radiator mounts around to face backward versus forward, which allows the radiator to lay forward. Not necessary for clearance with the new fans.
The max current is 19.5 amps, and airflow is ~2000 CFM (Cubic Feet per Minute).
Chuck Melton
