That looks like a fabulous combination for a street car. I have a very similar setup using a Comp cams 270HR. 215, 215 @.050 and 110 LSA. Flat tops, Blue Thunder and MSD. Very happy with the torque and driveability.
I had the pleasure of being present at the dyno run with Santos. Initially, tested with 36 degrees advance. Results improved slightly with 38 degrees - perhaps, 5 HP. Used GTS headers. The race shop was very complimentary regarding the build and power output.
