It will be painted in same semi gloss Black as the Fairings on either side of the Engine Cover.
@push, yes I was busy last winter and now run a 393 stroker with Trick flow Heads, Trick Flow single plane and all sorts of upgrades. I had it on a running Dyno but unfortunately I found I had an Ignition coil issue so it didn't perform well above 5000 RPM (now fixed) so we couldn't get a reliable reading for max power. Max peak on the runs were 485 HP and the Torque peaked at 665 NM/490 Lb-ft. Also I subsequently realized another obstacle that my Hydraulic Roller Lifters are giving up at around 6100 RPM, so will replace them with solid Lifters but that is a Winter Project since Summer time = Driving Time.............. ;-)
Nice! What are you cam specs? And how's the "around town" driveability when you're not putting your foot into it hard?
Garth here are my Cam specs, I can't provide you with all the details as I don't have the Cam Chart with me now (on the road) The Engine runs smooth and pulls from 2000rpm and upwards.
Lunati’s Voodoo series of camshafts deliver more area under the curve than any other series of camshafts. This means more throttle response, quicker acceleration, more vacuum and better efficiency. These factors, combined with maximum horsepower and torque, make Voodoo camshafts the perfect choice for a wide range of high performance applications.
Retro-Fit Hydraulic Roller Cam. High performance street/bracket cam. Needs 10:1 compression minimum, increased induction system and exhaust. Needs 3.55+ gearing. Very strong above 3500 RPM.
Advertised Duration (Int/Exh): 282/290
Duration @ .050 (Int/Exh): 231/239
Gross Valve Lift (Int/Exh): 241/249
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2600-6600
Includes: Cam & Lifters (#72335-16)
Part Number: 20320712LK
