Today was my big day, I got the car on the lift, changed out the oil filter, engine and gearbox oils, I was SUPER careful to not touch any wiring. I already spent all week troubleshooting all the little stupid electrical issues, blinkers, taillights, headlight, got all that crap done and was ready to change out the fluids and check out the underside.
Everything all went great, when it was time to fire the car up and warm it up, do final oil level checks, the car started with it's normal VROOM! and then died. Long cranks, no start.
Fuel pressure is good, I hear it prime when I hit the key, fuel prssure gauge shows pressure.
Pulled a plug wire and check for spark with a separate grounded plug, no spark.
Car has MSD ignition, Haltech driving the FI and timing (I think).
Distributor has Unilite (no points) and I plan to install a new one tomorrow first thing.
Tried going over everything I touched, checked everything I touched, never touched any wiring.
Just my luck though, things are going pretty good and then BAM, I make some progress, and then it dies on me.
Car's stuck now at a friend's shop, I'll be back there at 9am working on it until I get this issue solved. My new car HAS to run! it HAS to start, and be reliable.
I'll know more tomorrow, I have to pull the air cleaners, and rear covers off so I can get to the distributor, and just start troubleshooting. I'm no expert though.
I'm sure it's something stupid like a loose wire or fuse that got knocked, but I'm really bummed right now. I was hoping to make forward progress.
I guess I'll be honing my troubleshooting skills here tomorrow.
