Hello Everyone.
My 74 Pantera (still with the original 351)has been developing a slight vibration, that can be felt between 1800 to 2300 rpm. Sitting still or driving, it is very obvious.
My gut feeling is the harmonic balancer may be the culprit.I looked closely at it, and it appears ok, but maybe the outer ring has moved, even slightly and is not visible. It also is the original unit. So, I think that is what I should try first. Engine idles smooth and runs strong otherwise.
A Romac #0203 is out of my budget, and I have mixed feelings about having mine rebuilt. Anyone have good results with a Dayco PB1082ST? Or some other brand you are happy with? Let know, thanks to all.
