I went through this exercise some time back. The first thing I did was build an adjustable jig. With the jig I mounted the original suspension and was marked and adjustable to incorporate changes before building another set of arms:
I have since given this away.
Second I approached it slightly different and laser cut arms. I was able to make the changes needed in the drawing program. Being able to draw meant I could add or change any parameter I wanted. The arms were cut and welded. There are several things I really liked about these arms:
1. Easy to change target specs
2. The arms look original!
3. The arms are adjustable in caster, width and caster.
Mine have 6.5 +/-1 degrees of caster. (I am running power steering).
Since getting the car running I have found I was a bit tight on the fenders. I was able to pull the a-arms in and gain more clearance. That kind of adjust ability is enormous. If I don't like the dimensions, modify drawing, re-cut! I have no spacers as the a-arms are cut to fit the car.
I am too swamped to make another set at this point but it is a different avenue to pursue. I also don't have other Pantera's here to test them on so the project has basically be shelved:
