I'm in the process of installing a front condenser and need advise as to where to locate the lines in a 71 P car. I need advise on all the lines from the compressor to the condenser, condenser to the evap and then back to the compressor. I'm using a new Vintage Air unit, not the standard P car unit, but the connections are in the same location. The car is almost completely disassembled, so access to everything is available.
