Larry -
that's what's funny about this. maybe I need to look closer.
There are three bolt holes that align in the upraghn and steering arm, and corresponding, aligning holes in the dust shield.
I can not believe only two bolts go in there.
Thanks for the picture, though. More detective wokr requried!
In comparing Larry's & the Kid's photos, they are NOT similar.
It appears that Kid's photo shows ALL bolt heads as being 6 point heads ( No roundness in any bolts) vs the "1" rounded bolt head in larry's photo.
Due to the factory "Speed of Assembly Time Constraints" it would make NO sense to have a rounded headed bolt that requires more time & a different socket to tighten.
It would forego the "Bastard Bolt" & utilize the same "3" type 6 headed bolts...Mark
Which begs to ask the question..."What/Why is the purpose for a different headed bolt?!
As there is NO clearance issue that I am aware of that would necessitate/require a different headed bolt, being that the finished height is the SAME!
Why does the "Kid's" photo show ALL 6 point bolts being used?...Mark
