Any ideas, after I drive the car to operating temperature, (around 210 degrees, approx), I turn off the car, I can smell gas and can hear fuel boiling in the carb. It will restart but Idle's poorly for a short time, then It will be ok. Should I install a carb heat insulator, or is the car still running a little warm??
Good phenolic spacers are widely available, Summit, Jegs, etc all have them. Use the largest that will fit, I ran the 1/2" 4-hole model to promote velocity. The B2 spacer is unique in that it has a metal tube exiting from the front of it that runs to the PCV in the rear of the right hand valve cover. In terms of insulating properties, there are much better spacers now available. Good luck..
When I had a holley, my car boiled fuel all the time. You could even hear it. I had the carb mounted right on the intake. I first tried a multiple plate/gasket thing that worked so-so. Best is to use a plastic or phoenelic insulator. One with 4 holes works best and if only 1/2 inch thick, it still let the carb stay under the screen. Best solution is to switch to EFI. Smiler
