I looked for previous posts but did not see an answer to this: I have the gas tank out of the car and noticed that the little float on the tank level sender has about a teaspoon of fuel in it. This does not seem right - should I get another? Are they available? Second question - the sock on the end of the fuel pick up tube has a small amount of dirt on it, less than I expected. Can I just blow this off with carb cleaner, or should it be replaced? Thanks
A float must not have any liquid inside; this denotes a leak, which will constantly change the gauge readings. I replaced mine using a new float from an early '70s Alfa Romeo. It was identical to the Pantera float, and cheap as I remember. The sock is better removed and discarded. They tend to cake up with varnish, cutting fuel flow and making your fuel pump work that much harder. Instead, use an external fuel filter with a replaceable element, attached between the tank and pump. Hooking a filter the other way causes it to be pressurized which can and has caused engine fires. Its also not legal for open track events, for the same reason.You can also discard the little fuel filter inside your carb's inlet fitting- they plug up rapidly and cause fuel-feed problems. Do NOT use one of those little glass filters, either. They have been known to spontaneously disassemble while the engine is running. Jegs, Summit and other speed shops sell good fuel filters you can trust to stay together.
