Mark,
I sealed my tank with Eastwood Gas Tank Sealer and it worked just like it's supposed to. It seals any pinholes that you may have and dries to a rock hard finish. You can either buy a kit that includes products to clean the tank before applying the sealer, or you can buy the sealer on its own. I just bought the sealer and had a radiator shop hot tank my gas tank, to clean it out. A radiator shop can also fix any holes that may be too large to qualify as "pinholes". I also had the tank powder coated before using the sealer.
Dave
Red Kote is an excellent choice. I am running a tank now that was coated with it and no problems. My original tank,which is now a spare,had pinholes after I acid-etched the inside to remove the rust. The Red Kote will seal it up nicely when I'm done.
I bought mine from a tractor supply store online.
Good luck with your project.
