Jack, TAI
thank you for the information.What a great resource this site has helped me with many questions about my car, which my father owned before me and unfortunately did not have this resource to turn to therefore struggled with a lot of misinformation from hometown mechanics that did little or no good. The car now runs better than ever has,well it did before the gas tank started leaking anyway, mainly due to this WebSite linking me up with a supplier or answering my questions or reading the answers for similar problems listed on the board. Thanks!
Now that I have a little more time I'll try to explain a bit clearer. My gas tank was leaking,I am sure you are aware as I am now,the procedure to remove and repair or replace the gas tank properly. Well the gas tanks is out,.
Looking down into the engine compartment at what I suppose you would call the frame, that is what I was talking about welding. I'm not sure but it sounds like you're talking about the exterior body parts, which makes sense since I said "body". Is your answer the same for the frame? Thanks again .
