Hi, I own a Pantera wich have steel original fender flares.
The pree owner weld some ugly tips on them, so I decide to weld some new fenderflares from hall on my car.
But they do not fit !
They are about 3 cm thicker than my old flares and look verry ugly.
My old flares are "flat" the new ones are round.
Do you know if there were a special version in the past from the pantera?
Or do you cut the hall fender flares ?
Or do you use spacers on the wheels together with the hall flares ?
Thanks
Peter
Peter,
Many of the vendors GRP4 steel flares are notorious for being a really bad fit and finish requiring lots of work. I returned the steel set I purchased and went for fiberglass as the originals used. If you have steel on your car they are not original from the factory.
If they are much wider is it possible you have steel GTS flares and not GRP4?
Typically people are using wider wheels (10" front and 13" rear) with offsets specifically for the wider body/flares. This is in keeping with the originals that used the wide Campi 10 spoke wheels. That said there is nothings topping you using wheel spacers, although they would need to be quite wide to push the wheel from a narrow body out to a flared.
Hi Julian, thanks for your email.
I am so sorry but I can not upload some pictures here from my cellphone.
The steel gp4 flares would be realy a lot of work to make them fit.
The pree owner sold his 13x15 campis so I only have 10x15 campy but they look to small on this car. I bought some new 17x12 wheels and 335/ 35 r17 tires and they look realy nice on my car. BUT : when I install the "original" fender flaires the 335 tires are 3-4 cm to small!
The fender flares will stand 4 and front side about 7 cm away from the tires!
  • 20160830_160835-1-1
The original Gt4/gr4 flares were rounded and fiberglass, so the flares welded to your car are not original. The Hall flares in form and shape looks like the original glasfiber ones. The factory never installed steel flares.
The original fiberglas flares looks like in the Picture below and are available from most of the vendors.
  • IMG_1728
I do not know exactly if this is right, but there is an other one gt4 pantera here in Austria wich have also steel flares...
I heard that detomaso did some cars for shows and they had weldet steel flares.
This must be true, because the owner of the other one car have multiple sclerose since 25jears and there is rust everywhere on this gt4 because nobody drives it since this time.
It is so a sad storry but he do not sell the car.
He think that one time, he will drive it again.
My Pantera also has steel GRP4 / GT5 flares from the factory
Bdud -
Could you post up a couple pictures? While I don't know anything about Peter's car, the design of his fenders doesn't resemble the (few)GT4/Group 4 cars I have seen. They look custom made to me, but I might be wrong.
It would be interesting to see what yours look like.
