The Pantera I purchased #5972, included a GTS mini Air Dam 'Not Installed'.
This air dam is a simple flat dam with a very
small lip on one side.
What's the best attachment method?
Thanks for your suggestions ...
quote:I use sheet metal screws. I like to spread out the contact patch by cutting 2" lengths of a 1/4" hard plastic tube, drilling them in the center (like a Propeller) and running the screws through the drilled hole.
