Hall Super Stopper II Front Brake Upgrade For Sale ($600)
Includes:
2 SSII Aluminum Calipers with Mounting Brackets and Porterfield Pads
2 SSII Cast Iron, Vented Rotors
1 SSII Master Cylinder
1 SSII Vacuum Booster
(Note � Rear calipers and rotors are not included)
This brake system is approximately 3 years old and is in perfect shape. The SSII calipers will clear stock 15� Campys and are an excellent upgrade for street performance and the track (track events, autocross, etc). The calipers are manufactured by PBR and have fresh Porterfield street/track pads (3/4 pad left). The master cylinder is a dual master cylinder with 1-1/16" piston. The booster fits the stock Pantera mounting holes but is slightly larger diameter than the stock booster.
Installation is almost a straight bolt-on and is easily performed. The stock brake lines have to be bent and connected up to the new master cylinder, longer bolts are required for caliper mounting (available at a good hardware store), and the left-side inner trunk sheet metal needs minor adjusting (a few hammer whacks) to clear the larger booster.
For reference, Hall Pantera sells the complete Super Stopper II system for around $2000.
Contact David Bell at:
(281) 397-9279
or
davidabell@worldnet.att.net
[This message has been edited by mdbell (edited 01-01-2003).]
