Thanks for all input! :-)
I have repaired and replaced the engine mount lucky I'm small so I didn't have to remove the dash and roll cage... :-(
I must / should replace the fan blades, but I must take loose the whole fan unit for measuring the stock fan blades, so I know I'm buying the right one ...
I'll make a new stronghold bracket in aluminum in the winter I don't want to screw more now in the summer.
I have also searched more and found some useful info.
The GENAIRE blower fans like the one in most Ford era Panteras are pretty generic and were used in other specialty vehicles like some busses and RVs, I think. I'm very happy with my new 3 speed US made motor. It fit right in without modifications to my original GENAIRE "made in OHIO" fans and housing. It blows at least twice as much air on Hi as the original. I suggest you get one. Not expensive either.
The new 3 speed motor is a BM4320. I learned this from this DeTomaso list years ago. I didn't invent it. Just Google BM4320.
http://poca.com/pipermail/deto...2-August/063823.html------------------
3 speed blower motors from Air-Tique before they closed.
Has more power than stock unit and doesn't deface the original appearance of the car!
The generic name for seems to be BM4320.
It is available from other suppliers at reasonable prices.
http://poca.com/pipermail/deto...009-July/029854.html------------------
http://www.polarbearinc.com/PB...ht.html#Anchor-61408http://www.gamela.com.tw/M65078.htmlhttp://airblower.replacefinder...-pm381-blower-motor/http://clickbuys.net/product.php?asin=B000C7M72A------------------
solutions on three speed switch: When I installed mine, I just hooked the low speed to the unused switch at the bottom of the console while using the original fan switch for the medium and high settings. Not totally stock but stock looking.
http://poca.com/pipermail/deto...2-August/063825.html------------------
I used the original three position switch in the stock bottom position to give OFF/AIR/AC positions. This also selects the condenser relay full time when the AC is on. In either AIR or AC position, the fan runs in LOW speed with the blower fan switch in OFF position.
The original blower FAN switch runs MED in LOW position and HI in HI position.
The blower fan is only off if both the AIR switch and the FAN switch are OFF.
I use a little electric Mercedes heater pump for hot coolant circulation through the heater core. I hid a tiny microswitch inside the heater control so that it only runs when the TEMP lever is in HOT position. Other wise NO hot coolant flows through the core.
If the AIR position is selected and the TEMP lever is not in HOT, the fan blows air that is not heated or cooled.
http://poca.com/pipermail/deto...2-August/063826.html ------------------
PanteraDoug
where did you find that VDO is a three speed motor?
My other half has also cracked I fixed it years ago, I fixed mine like this.
Thanks for all help!
Anders
