Hello!
New guy here. I recently aquired #1438. It had been in controlled storage for a long time. I am bringing it back. I have it running and driving after going through all the systems and fluids. I am starting now to address systems that need attention.
Coolant Tubes
I have bought the stainless coolant tubes along with the rubber bushes and will be installing them. My new guy question is;
Can you remove the tubes by sliding them forward (sliding them toward the rear looks like you would run into the oil pan)?
Next question,
Is there a source for the soft hoses that I can buy in bulk and cut? Looks like Gates green line might work. What is the Inside diameter of the hose (so I buy the right one)?
Thank you in advance for your advice and help!
BobPantera
  • 1971 Pantera - #1438
You have to cut the pipes under the car to get them out…
Gates hoses are the correct hoses to use..
you need two sizes.. Measure the pipes you have to find the correct ID for them.. or call
PI Motorsports,  714-744-1398
they probably can send you all the Gates hoses already cut for usage
and please double clamp them..
Here’s what I did
https://pantera.infopop.cc/top...to-rear-blow-to-suck
...you can slide the Tubes forward if you Cut the Forward tube 'Mount', to move the tubes Down and forward. No need to chop the Tube itself. Don't want to cut the mount, then you will cut the tube, the one whole tube, the other is already in halves...or wait until the Engine is removed, to remove and install tubes from the rear.
I use to provide the Stainless Tubes cut to 5 Foot Lengths (or was it 6 feet?), until shipping became too restrictive. Yes, the Diameter is 1-3/8".
I advise 2 clamps at Each Hose End. Stay away from Silicone Hose!! Gates 'Green-Stripe' is what You want. You should be able to find it at most 'NAPA' auto supply houses.
MJ
P.S. I also, used to work at the Norton Factory in Hayward, CA. Norton 'Hold Fast' Clamps. 25 Years. We Invented the 'Liner Clamp'! Among other Special Clamps. All were Stainless Steel. I personally Assembled over a Million Clamps and Couplings!!
