My heater valve under the dash is leaking water into my driver's side footwell. I recall seeing a post in the last few years in which someone posted the parts needed to rebuild the heater valve located under the dash, complete with part numbers etc. If I recall correctly, total cost of parts to rebuild was a few dollars, versus $150 for a new valve. Unfortunately, I've been searching and can't find it.
Does have this info can would you share it?
Thanks!
