I decided not to run a heater line from the pump. Instead I made what I call a P2T2. Name comes from something else.
I plugged the heater ports on the water pump. The miss aligned tubes push the water one direction and pulls it from another. I use a Vintage air valve to control flow.
This allows me to keep minimal heater hose in the front instead of running it from engine.
