Hi, 1st time user here.
I,m finishing up a restoration on my '72 Pre-L. The horn button does'nt bounce back when pressed. Can the spring be replaced or should I replace the whole directional stalk assy.? Also, when I bought the project car, mid-restoration, the motor had been rebuilt by what I believe is a reputable shop, but it has a mild valve tap after a few hours running time (but no road miles). How concerned should I be? Should I run it on the road for a while before I set about replacing push rods? Thanks. E.T.
