Good Morning.
Could someone ID the Electronic Ignition box I have? I would guess it was a 89 install. There are 2 wires, a red and green from the box that were going to the coil as well as the large Blue/blk wire and a group of wires that consist of the Orange wire to the starter relay. I want to verify the connections and see if there is a problem with the box. Also any recomendations on a new coil?
I believe the Blue/blk wire is from the tach and goes to the - side of the coil along with the green from the box. The Orange wire group and the Red from the box goes to the + side of the coil.
Thanks, Steve
