The billet bracket moves the bottles to side by side where the current overflow bottle is located. This means a) you can cut out the current pressure and overflow bottle straps and b) there will be new hose runs required to reach the new location.
Here's an older photo of my GT5 with relocated bottles, not too good quality but you get the jist.
  • _5
Thanks Dave big help.Appears you left the old block in place that held the expantion tank did you mount to this or under it. if so did you remove the threaded studs that held the clamp on. Next ? did you drill all the way throught the rail into the wheel well to bolt on the billet bracket?
Cheers and Thanks guys
cj
Re the 'aim' of the upper water pipe being off: I've seen this li'l problem surface on more than one vendor's upper pipe assembly. The angle needed to line up with the tank inlet will depend a lot on engine placement; if your car allows a big-cap distributor, the set-back of that engine will necessarily be different than another car in which there's no room for a big-cap distributor. So the water-pipe angle changes. A simpler solution to cutting, welding and re-polishing the pipe might be to drill multiple mount hoses in the tank brackets, as engine height won't change, only fore-and-aft placement. But this fix will depend on the design of each vendor's mount bracket. Maybe an 'adapter bracket' between main bracket & body, as seems to be shown in one photo, would work?
