I have blocked the heat passages in past engines, and I DO NOT recommend it! It only resulted in rough idling and poorer performance. This modification is performed on engines that are ran at the drags or road races on 90+ degree days, out in the desert. On a 'street' engine, this mod will not only slow the warming-up of the choke and the engine on cold mornings, but will cause 'hard starting', less efficient fuel atomization which keeps the fuel 'droplets' out of suspension and lowers fuel economy and washes the lubricating oil off of the piston rings and will cause rapid ring, piston and cylinder wall, wear. Since 'Heat is Energy'(Horsepower)your engine will be making less of it. If you still insist on blocking the passages, don't bother 'driving' aluminum blocks into them! They will only disintagrate over a short period of time. The best, long lasting way, is to just slide a very thin (aprox. .020")sheet of Stainless Steel UNDER the intake manifold gasket and only covering that Port on each side. One of the best improvements you can make for increasing Horsepower (and Torque), is to create a 'Cold Air Induction' this will account for a true 10% increase!! That's 33 Horsepower on a '71 Engine! P.S. You can also add a 1 inch thick phenelic (plastic) spacer under the carburater, for heat insulation.
