hello all- has anyone seen or made a set of lifting bars? i remember seeing something a while ago- square tubing/ bar stock for a floor jack designed to safely lift the car- one for the front- one for the rear
One suggestion if you look at the bar closely... Make one cut in the bar just wide enough so the pinch weld fits into it, and then make the second cut about double the width. This makes your positioning of the bar more repeatable - the thin cut "indexes" the bar position.
