Because the rear glass is flat, if you have the cracked original you can use it as the pattern for your local glass store to cut a new one from auto safety glass. I broke my rear window during installation s couple years ago, the replacement fit perfectly and cost about $150.
If you don't have the original anymore, I may still have my broken one and can trace a pattern.
I hope this helps.
Matt
