Originally posted by Simon:..
Are you not scary that the bolts/tread ends come out of the intake?
Simon
I had the same fear when I first saw one of thos plates. But I did the calcs for that size bolt, that depth in aluminum and the pull out force was high enough for even me to use one.
my short term memory is gone, so this is just my gut, but I think using one bolt out of the 4 was just suffcient so using the 4 bolts gave me the 5:1 safety margin used for rigging, I would and recomend the bolts be torqued to the correct spec for being used in what ever metal the intake is
