Used Mallory mechanical advance distributor part #3756701. I bought for a project but never used, not sure if it works.
Description from online: Description from online: These Mallory Unilite distributors give you accurate, maintenance-free ignition timing. Instead of old-fashioned points systems, they have photo-optic, LED-triggering systems that never vary or wear out. You get increased rpm potential, improved combustion, longer spark plug life, and better cold-weather starting. Hooking one up is a simple 3-wire connection, and they come with your choice of adjustable mechanical and/or vacuum advance, self-lubricating bushings, and a Super-Duty cap and rotor. Ballast resistor required, Active Power Filter is recommended. Top of distributor cap sits 7.375 in. from block.
I found a few new units on eBay for $250+
$75 + shipping
Please PM if interested.
